show sntp-client
show sntp-client
Description
Displays the DNS configuration.
Syntax Description
Default
N/A.
Usage Guidelines
Displays configuration and statistics information of SNTP client.
The following command displays the SNTP configuration:
show sntp-client
The following is sample output from this command:
SNTP client is enabled
SNTP time is valid
Primary server: 172.17.1.104
Secondary server: 172.17.1.104
Query interval: 64
Last valid SNTP update: From server 172.17.1.104, on Wed Oct 30 22:46:03 2003
SNTPC Statistics:
Packets transmitted:
to primary server:            1
to secondary server:          0
Packets received with valid time:
from Primary server:          1
from Secondary server:        0
from Broadcast server:        0
Packets received without valid time:
from Primary server:          0
Replies not received to requests:
Platform Availability
